Piping an air vent on a relief valve tapping
there is a 3/4 inch relief valve port next to the supply tapping . We used to combine this tapping with the air eliminator . But ASME frowns on this idea and I'm not sure why . I guess they believe there is a better chance of something corroding downstream with more fittings and choking off the relief ? If this was the case , what if we use brass for all the fittings from the 3/4 tee ?
Also , to make the 3/4 port eliminate air better , some of the guys have been using a 1 1/2 inch by 1 1/4 bushing , threaded all the way on the 1 1/4 - right into the supply with a 1 1/4 close nipple threaded into the bottom part of the bushing . The close nipple sits lower than the 3/4 relief and air elimination tapping in the boiler , hopefully supplying air free water to the system . Is this another no-no idea ? Thanks for any help .
Air eliminator
I was wondering the same thing Ron. Why isn't there an internal air baffle in these boilers? I would guess the majority of oil boilers are being sold as replacements. The space required to properly install an airscoop just isn't there in alot of homes.0 -
That is it
in a nutshell . Almost every job we install is in a tight spot and never have the required dimensions to pipe an airscoop to specs . Other brands of boilers we have used in the past that had a built in airscoop worked excellent . The majority of systems we replace are simple 2 zone baseboard , and a good purge with a simple air eliminator on the boiler is usually all we need .
I know after touring Burnham that adding an internal baffle would be a tall order , but I have to ask anyway . Customer support is top notch and I know they will at the least consider the idea .0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
