bypass valve
K.Black
Member Posts: 26
I am installing a six zone two pipe reverse return system and I want to know if I need a diff. pressure valve to be put in . The zone valves are on the supply so is the pump also anybody use the new B&G flange kits check included. I read an old thread about a pump controler has anyone used this approach? THANKS
My rule
is 5 or more zone valves install a properly sized and adjusted PAV. Depends too onn the pump used.
I like to see a ball valve on one side of a PAV to aid in power purging.
If the pump has zone valves downstream really no need for a check valve flange set.
This article has more how and whys about installing and adjusting PAVs.
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,29498,00.html
hot rod
pav valves
Hot Rod I cant seem to find this page it keeps coming up page not found how do I get it from pmmag another way? I am looking forward to your class at ish-na0 -
Go to
www.pmmag.com click on "search archives" in the yellow box. Then scroll down to July 2001. Next scroll down to columns to get to Siggys "As the Zone Valve Closes"
Plenty of good info in those old issues. See you at ISH!
hot rod
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
