Synchronous Valves
Dan Stine
Member Posts: 1
I have a vacuum steam system, the vacuum setpoint is controlled by a "WeatherDial" system from Synchronized Systems Company (Detroit, MI), I believe installed in the mid '50's. The controls vary the vacuum setting based on OA temperature (variable vacuum system). I also have 3 valves in the building labeled on the drawings as "Synchronous Valves". I'm not sure how this system is designed to operate, does anyone have information they can share with me? Thanks!
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
