Buderus 215
kevin coppinger_4
Member Posts: 2,124
Carlin EZ66 in a Buderus 215 vs. a Riello F10? I have heard many good thing about riello but the price difference is hefty... I usually use the ez1 on the 115 series but this is a much bigger boiler....ty, kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Don't know about the EZ66, never seen one. Have used a 99CRD with mixed results. Replaced it with the Reillo and got great results!!!0 -
the 66....is the latest
improvements to the 99crd. But I was hoping for anyone having results to the changes...kpc
Muffler
If you go with the Riello better try the muffler for it, That sucker is loud.I have put a few larger 215's in with the Riello. I'd be intersted if any one has tried the muffler.
No experience with the new Carlin for this application/ I am told it has a special tube.
Regards
Robert0 -
Approximately 1 1/2 years ago there was an issue with the Carlin 99FRD in the G215/4 and G215/5. Carlin and Buderus worked together to resolve the issue and the EZ66 Burner was the result. The changes are to the primary control, air tube and combustion head. To date the EZ66 has preformed quite well.
With regards to noise. It has been determined the noise is the sound waves generated by the burner that travel throught the boiler and when they enter the chimney it creates a roaring sound. This has occured with other burners besides Riello. Chimney size and shape seems to be the factor for causing the noise. Comments from the field are the muffler works very well.0 -
thanks....
I will give it a shot....Iwhat type of chimneys seem to give it a louder than usual? kpc
There has not been a pattern with regards to what type of chimney for this noise to occur. We have heard it on tall single flue brick chimneys with and without liners, multi flue chimneys, etc..
If there are any questions, please feel free to contact us.
The Riello Roar
Well my experience is that Riello's seem a little louder.
If I were really concerned about noise i would try an insulated ss liner. Has any one tried that?
regards
Robert0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
