non- barrier radiant tubbing
When instaling a radiant system with non-barrier pex tubbing it is commmon practice to install a flat plate heat exchanger and separate the boiler water from the o2 in the pex. Does it also require a bronze body curculator to prevent premature pump failure.
Don
  • pumps
    Don
  • steve gates
    steve gates Member Posts: 329
    yes
    and use brass and copper S/S exp tank ect. With all the extra cast of these materials why use a less expensive tube?
