RADIANT TUBING
Nick W
Member Posts: 200
I HAVE COME ACROSS A RADIANT TUBING I HAVE NEVER SEEN OR HEARD OF.IT IS CALLED DURA-POLY XL,RADIANT FLOOR COMPANY HEAT EXCHANGER TUBING.
WHAT I REALLY NEED TO KNOW IS IF THIS TUBING HAS AN O2 BARRIER OR NOT,AS WELL AS ANY OTHER INFO ANYONE MIGHT HAVE.
THANK-YOU,JOE PERETTI.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=290&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
shhhhh
Joe turnoff the capital lock, no shouting
no
No oxygen barrier. and do not follow their recomendation that installing their pipe 18" o.c. in slabs is ok unless it's a slab that is never going to be living space and will never have rapid temperature changes and heat striping is no concern whatsoever. You will get heat striping, and the slab will react very slowly if it has to ramp up temperature for any reason if you install at such a wide on center.
And for all that is holy, do NOT install an open system! Use a heat exchanger at least.
_______________________________
Northeast Radiant Technology, LLC
Robert Brown, Co-Owner
NRTradiant.com0 -
Excellent response
And dead-nuts on the money.
Radiant tubing....
Use Wirsbo and you cant go wrong! They have awesome tubing available for any application you could think of.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
