Deck Snowmelt?
Jeffrey Campbell
Member Posts: 51
I have gotten into a situation where I am following another contractor and cleaning up the job right. The project is very far along and my job is to finish the snowmelt system. My question is can you snowmelt an exposed deck with 5/8" tubing embedded in only 1 1/2" concrete with R-30+ insulation under? The client wants a class 3 melt so the system will run idle or until he gets the first bill. See ya in Boston
Simply Rad
Simply Rad
Call me
Give me a call if you would like to discuss your project and we can run through the calculations to see what it should do.
Tim D.0 -
Tim Doran what is your phone number?
I would like to talk to you about snowmelt decking.
You forgot to give me your phone #.
Thanks Jeffrey0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
