millivolt system with pumps
Jerry_7
Member Posts: 23
I am converting a gravity system to baseboard. I'm keeping the old boiler that is about 10 years old. Someone replaced the old boiler and for some reason left the system gravity. I didn't notice that the boiler runs on millivolts and I was just wondering if it's possible to add two baseboard loops and leave the gas valve millivolt
Yes.
Check out the Honeywell L8148J1009.
Might be just the ticket.
Let us know how you make out.
Doesn't it just require using a relay with a 24V coil for the burner/controls/where the thermostat used to be.
Matty0 -
He wants to keep
the PP/MV generator, MV 'stat, MV gas valve and MV pilot assembly.
To switch it all, might involve robbing a bank AND his first born child (:-o)
use0 -
thank you ken
Thanks0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
