Slant Fin Boiler
lizzy
Member Posts: 6
I am going to put a boiler in a closet alongside a exterior wall for hot water baseboard heat.
This is a major remodel. I tore the roof off a ranch and made a 1 and a half story house.
It would be nice not to run a new chimney so I have been looking at direct vent Burnhams and Weil Mclains.
I stopped in a supply house here in Central Indiana. They said that they could get me a Slant Fin sealed combustion direct vent boiler for nearly 600 dollars less than the Weil Mclain or Burnham.
I know that Slant Fin has been around for a long time and I believe that they are a very reputable company. But I have been around long enough myself to know that you get what you pay for.
The boiler is called a VSPH=90 from their Victory series.
Has anyone had any experience with this boiler?
Slant Fin direct vent, sealed combustion
Has anyone had any experience with this boiler?0 -
Slant/Fin sealed combustion boiler
Slant/Fin has recently tightened up its product offering in sealed combustion products. The VSP or VSPH have proven technologies and the ones I have inspected are very quiet. In my opinion, it's a good value.0 -
Where?
Didn't know anybody in this area was peddling Slant/Fin at the moment! Must not stock it or let their customers know!0 -
Slant;/Fin makes a good boiler
and if anything should go wrong, they have great people to back it up.
As with any boiler, it must be installed properly to perform well.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
i live in brooklyn NY...
and have seen vsph boilers being made - they are without a doubt the best boiler for the buck hands down and if you pipe it with primary/secondary/var-speed-injection a-la-tekmar 361 you will have a really great economical and long lived system noel murdough is always there to help you nmurdough@slantfin.com 800-873-4346 or 516-484-2610
just as an example my avg slant fin install is designed for 180/160 20 day, but with the tekmar setup, on the avg day, the boiler loop cycles between 146-154 and the system loop136-142 the boiler runs 2-3min out of 15 and yes, BaseBoards work with supply temps way below the standard tables which start at 140 tekmar knows this, and uses the outdoor temp to aggressively drop the BB supply temp!!! saves a bundle without corroding or short-cycling the boiler you will get efficiencies and cost reductions approaching those with condensing boilers and radiant heat
sorry for sounding like a slant-fin or tekmar salesman
ps make sure you follow the guidelines for venting I have seen too many direct vents discharged through the wall near a window where the gases can be sucked right back into the house
Jim, Slant Fin ..strong boiler.
I like slant fin...i buy mine in Novermber for the following season (place my order with the K-Supply here in Fairbanks alaska)i like riello burners and oil. then in May i order some more...:)0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 984 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
