flat rate
shawn laverty
Member Posts: 42
does any one know of any good companies that will set your flat rate for ya also how expensive is it because this t and m stuff does not work so hot all the time we should be making more money for knowledge and certafication
flat rate
I use NSPG and purchased it from Mark @ Service Doctors. Use the Service Doctors web site and mark can send you a demo I'm sure.0 -
If you're
having problems with T&M, FR will probably not help.
Knowing the cost of doing business is everything. The method deployed is irrelevant.
First, learn how to calculate what your expenses are for a given time frame (hour, day, month, etc.)- and then figure out what your hourly rate must be, just to break even. If you're a one-man show this can be tough.
FR will not solve your problems. But neither will T&M. The problem is in your knowledge of business accounting. A one-semester college course in BUS-101 a couple of nights a week might serve better than all the T&M/FR hustles on the planet.
The more vocal proponents of FR (on this website anyhow) will suggest your "salvation" rests with that scheme of pricing. My response to that notion appears at this link:
http://www.masterplumbers.com/plumbviews/2002/flatrate_revised1.asp
Makes you think if you want to go flat rate or TM what to watch for I think either way can work as long as you keep it fair for the employees and customers0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
