Bacharach sensor question (Rudy)?
DaveC
Member Posts: 201
Our PCA-25 combustion analyzer looks like it needs a new Oxygen sensor. The screen shows "error" and the Oxygen level stays at 20.9 % when put in the flue. The unit is about 3 years old, so a new sensor is due. However, when we open the unit up, we notice the wire leads to the 2 sensor pins are extremely loose. The leads connectors do not look like they opened up, otherwise I would just squeeze them down to make a better connection. It looks like they are not the right diameter or is there a purpose to the loose connection? Curious if you know? Thanks
Jim, Hope you don't mind my responding to this but I happen to know Rudy is on vacation enjoying time with his family
After that long in service you're probably right it may be time for a sensor? Depends how much you use the analyzer of course.
Any how in Rudy's absence Norm Grazier is a good, go to guy.
Norm Grazier
621 Hunt Valley Circle
New Kensington, PA 15068
1 800 736 4666
NormG@Bacharach-Inc.com
Hope that helps.
Your friend in the industry,
Alan R. Mercurio
Oil Tech TalkThere was an error rendering this rich post.
on that note
If it's been used as much as I suspect it may not hurt to send it in for a checkup..Just to get it ready for that lovely cold weather..JMHO0 -
Thanks, guys...
Norm says the terminals should be tight, which makes sense. I'll squeeze the connectors a little bit, but I still don't see why they are so loose to begin with. We use this just as much when it's 95* outside as when it's -9* outside - the lab never stops!0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
