trv
scott jacobson
Member Posts: 7
What is the best kind of trv valve to use integral sensor/setpoint or remote sensor ???
Depends
The trv head has to be located away from the heat effects of the radiation . If it can not , then use the remote.....0 -
it depends
Danfoss built in operators need to be installed horizontally, otherwise you will need to use one with a remote sensor. So it all depends on your applicaiton.
Also, ensure that there is proper air flow over the operator.
bb0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
