Anyone interested
tim smith
Member Posts: 2,841
I have made arrangements to have old style Roccoco bushings and maybe plugs made with the relief art around the rim, direct copy, i am just checking before I commit. The bushings would have a 3/4" blank hole in it with the outside threads machined on. You could either tap the 3/4 or drill and tap for larger hole in bushing. These would be bronze. Would anyone be interested. Appx. 20.00 ea.
Sounds cool Tim
I would take a couple. That would be great - we could make our own eccentric bushings. Mad Dog
Tim, is the hole
on-center, or eccentric? And do you plan on making them to fit different sizes of radiator tappings (1-1/4 to 2 inches) so they will fit different radiators? I know I can use eccentrics- they are hard to find so I try to save as many as possible when we change a radiator.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
size of bushings
Steamhead, they will probably be mostly 2" as this was the size on the rococco and federal style radiators. As far as the center tap, vs eccentric. I can have some cast with no hole in center so you could drill for eccentric and the rest would have the hole in the center of bushing.0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
