Quic Trac
RELY
Member Posts: 33
any ideas would be helpful thanks
we have
laid down a vapor barrier, then a layer of marine plywood with powerload shot pins and then applied the QT as normal.
Quick track
We attach the quicktrack directly to the concrete floor useing a trakfast gun.
If the cement floor isn't insulated below roll out a layer of foam insulation than shoot it down with the trakfast.It's much cheaper & faster per shot than "hilti" type pins.
Look on E-bay for trakfast guns there are usually a few on their at a good price.0 -
marine plywood was my thought but the new treatment will root
the metal track in the quic trac thanks for the help0 -
thanks for the come back I will check it out. How thick is the
foam that you use 1/4" roll out ?0 -
Quick track
Yes.We use 1/4" slab sheild.It's two layers of foam with aluminum in between them.0 -
why not just use.....
the Roth flooring system and glue it to the concrete?
It's your R3 insulation and transfer plate all in one.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 97 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
