Weezbo
Weezbo
Member Posts: 6,232
You can See the Gears Turning! :) now the beauty is all those new spec homes with recir hot water lines water makers stand alone radiant garage slabs and base board zones i can dash back re state the "I allow room for up- grade speel:) can offer out door reset blah blah blah :) fuel oil going up blah blah bla :) Hurray !"finally a "win" in my life for doing more in the first place:) I SO thank you for the offer...and Mostly , thank you for your thoughts..for once Something came together before i finished the job and went home sniveling:)) hurray! i am currently visualizing Food:)
Weezbo
Hey did you say you were looking for taco I series mixing valves? I might be able to help you out on that if you still cant get them.
S Davis
Apex Radiant Heating0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
