New floor - raising radiator
Bus Tarbox_2
Member Posts: 1
I removed the one-pipe system radiator to install a new subfloor and tiled kitchen floor. That done, now the supply valve is 1 and 1/8 inch below the radiator inlet. I had planned to set the radiator feet in four 1 and 1/8 inch holes through the tiles. It occurred to me that it might be easier to add a 1 and 1/4 inch extender to the riser below the supply valve, and then adjust the radiator above the new floor. Well, the "might be easier" part was until I tried to unthread the supply valve. Holding the riser with a strap wrench, and gently tapping the 12 inch pipe wrench on the supply valve got nowhere. Would a propane torch on the threaded fitting to the supply valve work to loosen? Or should I scrap the potential catastrophy of a broken riser, and just drill the four "radiator foot" holes?
Thank you,
Bus
Thank you,
Bus
do not set radiator in holes !!!
for a professional plumber that is a less than one hour jobbing call. remove valve, remove tailpiece spud from radiator and extend connection w/ new valve and connect radiator,check grade and test. collect cash and end of story.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
