hydronic towel warmers
marc
Member Posts: 203
how do you go about installing a towel warmer, more on the control strategy side. with weather responsive controls going into just about everything we do now, how do you achieve warm towels during wwsd, do you do a set point control, timer, trv, wild loop, just curious how everyone else tackles this problem. about 5-10 % of the customers ask about towel warmers with the boiler. but only have installed 5 or less. or do you just install an electric self contained, plug-in warmer. marc
In all honesty
Unless you already have a source of constant (or very nearly constant) circulation (either space heating or domestic hot water) use the oil-filled electric.
Properly loaded with towels they contribute little heat to the space and consequently have a small energy requirement.
As long as they are provided with a nearly constant source of heat, they do as they say and people want--WONDERFUL, fluffy and "thirsty" towels.0 -
towel warmer
You can tap into the hot water line going to the shower, send it through the towel warmer and back to the shower. I really like the control strategy.0 -
Here's a link to Instructions
Myson Towel Warmer Installation
Note: "Myson hydronic towel warmers take 20 to 30 minutes to heat towels properly. For this reason, we do not recommend piping towel warmers through shower valves."
IMHO that 20-30 minute period is an utter minimum--longer seems much better--particularly if you've folded the towels into 3-4 layers in order to fully load the warmer.0 -
Hydronic towel warmers
I've seen and used a number of these, and the typical installation that I've seen work well is to use one of those Danfoss self regulating control valves on the pipe connection. Very common approach in Europe, and can run off the same circuit as radiant floor heating.0 -
Myson
Good point, I was going to sweat up my own anyway. The local chrome plating shop can chrome it for $80.0 -
Towel Warmers
We usually pipe them just like a radiator; with our without a TRV and tell the owners that they will only have warm towels when it's cold outside.
We once installed one on the DHW circulating system and used venturi tees off the main to allow for TRV action.
If in DHW
I installed mine in a gravity recirculation loop. Towel warmer is the highest, farthest element of the loop.
It's right at the end of the loop where it changes from supply to return. With valve in warmer open, there's plenty of circulation; with valve closed, the loop still functions.
Photo shows temp less than an hour after the gravity loop became operational. I generally turn up the DHW temp in winter; down in summer. This was summer with supply at about 120°. The ¾" connection right above the thermometer supplies tub filler and towel warmer. The ½" connection to the right (just before loop sizes down from ¾" to ½") is the return from the warmer. This part of the loop is about 14' above the heat source and 50' or so away.0 -
domestic question
are there towel warmers rated for potable?? just curious, with a recirc. line on domestic this sounds like a pretty good idea. i also liked the idea of warm towels only when it is cold out. but some people also want warm floors in bathroom when the air is on. the towel warmers alone are very costly, not including the install and parts. thanks marc0 -
Answer
No! I have seen various brands of these fail prematurely when connected to potable water. Now with our own line of these, we are also stating not to connect them to potable hot water. They are intended for closed systems only.
Glenn Stanton
Burnham Hydronics0 -
Ive built
some stainless steel tube towel warmers for a DHW loop. The stainless "look" fit the bath decor and should last forever.
Close up shows the FIP 90's embedded in the wall for the rough in. Also a small bleeder port.
Make sure you insulate the entire DHW loop if you run it 24/7. insulate it even if you run intermitantly
hot rod
Buderus
We usually set them up on their own zone with a 45 minute timer so they can hit the timer when they get in the tub or shower.
Buderus just came out with a stainless towel warmer rated for potable.
S Davis
Apex Radiant Heating0 -
Do you
have a link for that radiator?
Alan
Sorry
Sorry it is Runtal that has that towel warmer.
You might have to talk to your Runtal Rep I don't think it is on their web site yet.
S Davis
Mine is a
Veha on the granite wall next to the claw foot tub. It is plumbed on its own lines to the manifold for the floor loops so the colder it is outside, the hotter the towel rack. The chill is taken off the bottom of the claw foot tub by the radiant floor.
http://www.veha.com/bathroom.html0 -
And we -
Pipe them with the same loop (parellel) as the bathroom radiant or hydronic zone. Warm only when it's cold outside. Usually controlled by the same thermostat (statlink) as the bathroom. While we sell them based on client comfort - it's usually supported by the need for supplemental heat in a smaller space.0 -
The Myson
materials are completely safe for potable water and units are tested to quite high pressure. Fit and finish are exceptional--both well reflected in price. Like anything though, it might spring a leak and if under domestic pressure it'll be a big one...
Here's hoping I never find out!0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 984 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
