RADIANT HELP
frank_25
Member Posts: 202
How have you guys sealed foundation penetrations when using multiple small pex lines? We're doing a 16 loop snow melt, and I'm planing to drill four holes thru the poured foundation, two at the front and two at the side walls, 8 loops thru each, supply and return. What kind of waterproffing material have you guys used? I've read that tar is a no-no.
I would sleeve the pex maybe with those plastic elbow sleeves that they sell. Then seal up your holes with whatever is correct , cement etc...0
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
