Old honeywell zone valve wireing
Don Baker
Member Posts: 23
I was sent on a job to wire up some old honeywell zone valves that I have never seen in my life before, there was no model number or wireing diagram...
The valve was big and clunky (24v) and looks to have an incorperated end switch. 5 wires... 1 white, 2 black and 2 red. I did manage to get the valve to open but it did not spring return so I am assuming it should be power return. Seems odd because they are run by a 2 wire thermostat.
If I powered up the 2 blacks the valve looked like it was opening properly, if I powered up the white and black the valve just kept rotating.
Unfortunatly the plumbers removed the wireing for a reno now it's up to the electrician to figgure out how they work. Any one know these beasts?
Without a base number this could be hard,
if you can find one go here, it's THE place to start.
http://hbctechlit.honeywell.com/0 -
Don, I have the wiring diagrams
and the specifications for those zone valves.
e-mail me at gastc@cox.net and give me a Fax number and your mailing address. I will fax diagrams and will mail specs in postal mail.0 -
Don has disappeared
Oh well this goes on all the time here on the Wall. Ask a question and then disappear. I will try to e-mail Don to see if I can help him out.
For those who may be wondering the Zone Valve he had is a V-8031 Honeywell Zone Valve, yes it uses a two wire series 80 thermostat. There was a comparable model back in those days the V2031 which used a three wire thermostat.
The 8031 is powered open and springs closed on more close observation it may be noted that terminals are labeled "W" "B" and "Y" Thermostat goes to W & B and the transformer is wired B to Y. The remaining two terminals are the end switch which go to "T" "T" on the relay.
The V-2031 was a power to open power to close model.0 -
Don hasn't disappeared
Sory Folks and thanks, I just went AWOL for the weekend to an antique motorcycle ralley. Business as usual tomorrow.
Tim I would apperaciate a fax of the wireing diagrams you spoke of, I will send the fax # to your email. Thanks again for all your help.
Don0
- 125 Chimneys & Flues
- 169 Indoor-Air Quality
