Chimney Liner
Jim Erhardt
Member Posts: 52
....for me to drop a liner in my masonry chimney. Tile lined, 18 years old, outside, approximately 20 feet tall, straight drop. I believe the inside dimension is around 8 inches square. One appliance vented into it - an oil fired boiler that runs under 400 degrees gross stack temperature.
Any recommendations a liner kit would be greatly appreciated!
Line L
Line L is a good chimney liner. THey make stainless steel ones I think0 -
Z-Flex...
is best know in the NE area. Prior to installing, check your boiler model # and firing rate. Check NFPA Appendix E (as a guide-line only, it is after all an appendix and therefore not a part of the code) for guidelines on needed or recommeded liner size. If 5" will handle it I'd go that way. SS liners can be a real adventure getting down a flue. The smaller the better from an installation standpoint. Be advised that you should consult the boiler manuf for approval on this. Other alternatives to flex cold be Dura-vents DVL or Selkirik's DS. Both L vent rated double wall insulated products. OD of both is about 7" on 6" id pipe0
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
