water volume????
Dave_34
Member Posts: 1
I have 4 flushometers 110' away from a 1-1/4 water main. If I ran two 3/4 or 1" pex lines off that main and then rejoined them to a 1-1/4 pipe under the bathroom and then fed the fixtures, do you think I will have enough volume of water. I have done this with gas before but never water. Thank you very much for your help.
Pressure
What is the available pressure?
Tim D.0 -
this might be helpful
but I'm not sure how accurate it is or anything. I think I got this from ME from a thread long ago. It will open an exel spread sheet with a volume calculator for any pipe size and length you plug in. Good Luck
http://pages.prodigy.net/rich_demartile/files/pipe-vol.xls
Larry0
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
