Dan - Two pipe direct return vs reverse return
TGO_54
TGO_54 Member Posts: 327
Hi Dan-
In one of your books you talk about using TRVs in a two pipe radiator system( hot water). It states that there is no reason to use reverse return on the main piping because the TRVs will balance the system. Is there any reason not to use a reverse return other that the added expence?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=278&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,712
    I think what I said
    was that if you're using reverse-return the system will balance, assuming the pressure drop is equal in all the circuits. Once you add TRVs, the pressure drop will always be changing so it makes more sense to go with direct-return.
    Retired and loving it.
  • TGO_54
    Hi Dan,
    Thanks for the reply.
    Assuming that the radiators are sized for the heat loss of each room on the coldest day, the TRV's should all be in the open position. If that is the case, then wouldn't the flow though the short run radiators be grater than the long runs? Would using reverse return eliminate or lessen the possabilty of this? I am laying out the supply mains for a panel radiator job, and the mains will just about make a loop in the house. It would be very simple to make the system a reverse return (no third pipe needed) but I want to be sure I am not creating a problem.
    Thanks.
  • DanHolohan
    They should
    but TRVs usually modulate when they're tracking the room temperature, trying to keep it within plus or minus a degree or so. Can't hurt to pipe it this way, but I'm not sure if it would make a difference.
