New Boiler needed
M J
Member Posts: 3
I currently have a Trianco heatmaker HW-M2-100 but have added another well insulated (R38/R19) 1600 sq feet and would like to upsize for expandability. It is propane driven. The Heatmaker was not a bad unit but it is now 11yrs old and I'm sure not as efficient. Last winter I had several issues and found it a nightmare to get parts for. Time for something better. Thanks all for your help. MJ
You may want to
check out the Burnham Minuteman II boiler. It is pretty much a close fit replacement for what you have. If you have space limitations, which you probably do, it will fit in the same space. Heating and Domestic Hot Water in the same package. Hope this helps.
Glenn Stanton
Burnham Hydronics0 -
Hey Glenn Stanton!
You answering emails these days?
I sent you one almost a week ago - and have yet to get a response.
Laars Endurance
is the direct replacement for Heatmaker. Trianco sold out to Laars and the Endurance is an upgraded version of Heatmaker.
Call Mark Hughes oat 1-800-900-9276 Ext 5401
Or e-mail at mhughes@laars.com
Web site www.laars.com0 -
Ken
Not sure why, but I didn't get your e-mail last week. I did get a forwarded copy tonight and responded to it. Just to be politically correct, make sure you are sending it to gstanton@burnham.com . Take care!
Glenn0 -
Aha!
Having looked at the forwarded copy I received tonight, it appears as though you sent it through the Burnham Web Site and it was received and hand forwarded from there. If that's the case, just send it direct from now on. Thanks.
Glenn0 -
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
