copper pipe
Capt.Dan
Member Posts: 19
What type of copper pipe should I be purchasing for my heating connections?, type M or L and can you tell me the differences? Thank-you. CaptDan
Copper tube
Hello,
"M" wall copper tube has a thinner wall thickness than "L" wall copper. I believe the entire country allows "M" wall for heating. However, some people prefer to use L for several considerations. For example, noise reduction, not as "spaghetti like" more resistant to aggressive water conditions. For the small price differeence, I would "go to L".
Bill0 -
Ten hut!
I have never seen a problem with M on a FHW heating system but that is only here in the great Commonwealth of Mass.
Others will give you feed back for their sections of the country and world.
E4 Jack
MA National Guard0 -
Mor L
i use both...M mostly L for looks or where freezing on a "down" system might be a bit of a bad itch to get back into.L is able to take more freezings. 80 K for under grounds ,yellow for DWV,then there are special pipes used in science experimentations where electrical wire doesnt get it.0 -
M for heat
L for domestic water
A lot of companies only use L so that plumbers dont mistakenly use M on water lines0 -
Call me conservative
but I use L on all FHW and domestic water piping both installed in my house and as a specifying engineer. Type M just has that thin feel to it and can kink and dent if you are threading it into a tight space. Subjective I know. But once bought, it goes forever. Just MHO...0 -
Brad
Twenty Five years in the trade and I have never used anything but M on Hydronics. Never a problem.
We did go thru a problem where some contractors were using M for water piping and it pitted right thru after about ten years. Massachusettes code is now L only for domestic water, but we still use M on heating systems. Allthough now its more pex-al-pex than anything.
Scott
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
