pipe volume
lchmb
Member Posts: 2,997
On an oil system with a pump fed system The main loop is 1 1/4in. fed by a pump set for 2 lbs. The main line rises 12 feet and then runs 20 feet out. I am just wondering if there is a formula to calculate how many gallon's per hour this could run...
Not sure
of how you would figure the volume in the pipes but I would guess no matter what the size of the pipes the GPH will be based on the feed pump.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
