Rust in old radiators.
Pete_11
Member Posts: 4
I am building my house & using a hot water system with old cast iron radiators. While water testing for leaks, I have noticed some of the radiators are very rusty inside. I have blown them out with air, & flushed them out with water - a lot has come out. I am worried though that some large chunks will become dislodged while the heating system is in operation and damage a circulator. What should I do? Is there a filter system I can install?
Here's two company's that make products.
First is Spirotherm, maker of the infamous spirovent, also make a dirt separator calle the Spirotrap,
http://www.spirotherm.com/dirt/
Another company is Garber Filters, known for their spin on fuel oil filters. They have a replacement boiler filter. Unfortunatly, they don't have info on their website, butI have seen magazine ads for it. E-mail them for more info.
http://www.garberfilters.com/
Please note I have not used either of these products, I'm just aware they are out there.0 -
new concept
install wye strainers before pump if circulator is pulling. if pumping away ,not necessary , garbage will end up in boiler.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
