Dan, pumping away question.
EJW
Member Posts: 321
Dan I am starting a baseboard job on Monday and am going to try your piping system from page 48 of Pumping away. The system will be 3 zones of heat and a indirect. Is it imperative to keep a full size supply main? I am using a Peerless EC that has 2" supply and 1 1/4 return. I'd like to drop the supply to 1 1/4, would this be ok? Thanks, EJW
I am not Dan the man
by far but if the 1 1/4 main can handle the flow for the zones then it should be fine. I assume there are three big zones since the EC is the larger line up in Peerless.0 -
Don't you sell hair care products?? lol
I agree.
Retired and loving it.0 -
yes actually
This heating stuff is just for fun.......I wish0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
