Help
John Fernandez_2
Member Posts: 40
My message has not yet received a reply. Maybe one of you wetheads might be able to help me out. John
You may need to clarify...
What you call the "priority" pump isn't really the pump for the priority zone (indirect water heater), but is the "primary" loop pump for the radiant zones? What control is on the boiler, also, would help?0 -
John I have replied to your post
see if you can give us a little more info.0
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
