Twin flow leak
Vinny baga doughnuts
Member Posts: 12
I recently installed a brand new twin flow fan coil unit.
Everything looked fine when I left, the customer called me several hours after I'd left telling me he had a leak.
It turns out the leak was on a return bend in the opposite side of the connections (factory joint).
Has anyone out there encountered problems with Twin Flow factory solder joints?
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
