Drilling in hole in cast iron kitchen sink
Plumb
Member Posts: 6
need some advice on drilling a hole in a cast iron kitchen sink.
easy drill
#1 start off with carbide tip 1/4" driil, driil through finish to cast iron.
#2 use 1/4" high speed driil go through cast iron.
#3 get cabide tiped hole saw ( size you want hole ) start drill using pilot hole made allready.
slow and steady.
allways works for me....0 -
Rich da man
is right on. It's a two step process with two different drills. The carbide cuts cleanly through the glaze, then any good holesaw takes it from there. Cast iron is fairly soft and easy to cut.
Watch your drill speed to prevent burning. Safety glasses, and brace youself and drill to prevent an embarassing snag and launch. Or worse a skid mark across the top of the sink I've been down both of those roads!
Most good tool supply shops have the combo.
hot rod
Diamond hole saw
If it something your going to do on a regular basis, I would invest in a diamond hole saw. I bought a 11/4" for about $80 and was worth every penny.0 -
The EASY way...
I don't know where you're at, but in Denver, Water Systems, Inc will drill the extra hole for you (for a minimal charge) If they screw it up, THEY eat it, not you...
ME
the easy way...
Just Say No!0 -
Diamond hole saw
I did buy a diamond hole saw, the cost was $48.00
If you need any Drilling or demolition equipment this place is great.
U.S. Diamond
1-800-582-1429
24-32 44th Street
Long Island City,N.Y. 111030 -
Thank You All
My little trick
I place a disposable coffee cup over the hole saw to catch all the metal shavings. J.Lockard0
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
