Skim port photo?
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,610
a good photo of a properly done skim port on a steam boiler. Got one that you'd like to share? Thanks.
Retired and loving it.
  • Almost.....
    I have a drawing.....
    http://www.slantfin.com/spec-galaxygxh.html
    Noel
  • DanHolohan
    Thanks, Noel,
    but I need something field-installed. Preferably with a full-size tee so that you can see the waterline while skimming. Thanks.
  • gerry gill
    gerry gill Member Posts: 3,078
    here is a couple
    the skim is off the outlet tee from the side outlet risers.. one we got fancy and piped to a drain..actually they are both piped to a drain..the arlington picture the skim pipe is the right side tee tho we also used a tee on the left side tho noone will probably ever skim it from that side.
    gwgillplumbingandheating.com
  • DanHolohan
    Thanks, Gerry.
    And nice use of the decal!
    I'd welcome any others anyone may have. Thanks.
