Steam Vac. system
Richard D._2
Member Posts: 156
I had to put in a 47-2 M/M today..It had a over fill prob. Bad float and just rotted..The tech. though it also had a bad vent because only 1 rad. puked water..Bring !A vvent and found it to be a Vac. system w/Hoffman and B&J Return Line traps..1 rad also had a 1A w/ the trap..I say their fix to a bad trap! How do you test a vac. system to make sure all rad are OK ...What is the best setting in oz.?All rad.seem to heat but want to be sure! Why did only 1 rad. puke water w/the overfill??? Thankyou all in advance...Richard
Is it Vacuum...
or Vapor? Were there any other devices in the piping around the boiler? The answers will help us identify the system and suggest a solution. Post photos if you can.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Hey steamhead
It has a Differental loop,No return linw tral in basement, 1/2"trapson all the rads. and the valve to rads. has a handle,w.closed,1/4/,1/2 etc.Thats all I saw so far..Thanks Richard0 -
It's Hoffman Vapor
covered in chapter 15 of "The Lost Art of Steam Heating". Check all the traps to see if any are letting steam into the dry return, including the crossover traps at the ends of the steam mains. Use a BIG vent on top of the Differential Loop- I like the Gorton #2. Remove the vents from the radiators and plug the openings, crank the Pressuretrol down and it should work great!
Consulting0 -
Yes
It has a LARGE vent on the loop..I think someone put the 1A in to fix the trap! Thanks for your fast reply! Ive got the bookandit well worn just wasnt sure of what I had ... Thanks again.Richard0
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
