Heating hot water indirectly with steam for a radiant loop
T.Ferns
Member Posts: 3
In the past we have been asked to heat domestic water indirectly off of a steam boiler. Does anyone have experience or knowledge of heating water for a radiant loop off an existing steam boiler?
Not quite the same but
you could use a tankless coil in the steamer and run it to an indirect tank.
Pull from the "domestic" side of the indirect for your rad zone.
Mark H
Everhot
makes an indirect that can be steam piped.
www.tfi-everhot.com0 -
one thought
Have had good luck w' heat transfer plates. I use a tee wye on the h/w loop off of the boiler w' a strainer. No risk of "mudding up" the indirect h/w heater0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 940 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
