Oil burner piping?
laundryman
Member Posts: 1
I am a contractor from pittsburgh helping my sister on a long distance job in NE Baltimore. Her existing system is a Burnham RS/110 boiler with CI rads. We are adding two zones of copper BB fed with 1/2" PEX. After checking Burnham's site they reccomend circ. zoning without P/S loops. Will there be enough flow through the boiler if only one BB loop is calling?
In pgh. I never deal with oil and I don't pretend to know anything about it. But I would like someone to check out her oil burner. Anyone close?
With a 20 degree temperature drop you can send about 14,000 btu's through a zone using 1/2" pex. If you are using conventional baseboard that is about 20' of board, that will usually heat about 300-400 square feet of living space. Hope this helps.0 -
go to the
"Find a Professional " bar at the top of the page type in your zip code for Baltimore.
Steamhead is a great resource near you. I think his firm is out of Towson MD
Regards
Robert
ME0 -
Here I am, LM (thanks, Robert)
this job sounds like it's right up our alley. Give us a call at (410) 821-3997. The voice mail is on if we're not in the office, and we check it several times a day. Or you can e-mail me.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0
- 86.5K THE MAIN WALL
- 54 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 929 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
