zone valves
jaybee
Member Posts: 128
can anyone explain to me about the arrows that are on the zone valves.I know that thjey are in the direction of the water flow, but this person told me that he could tell if it was located on the supply are the return no matter where they were in crawl space , spread out ect. how can he do this. I,m a newbi just trying to learn a have a lot of questions some guys just dont want to give me a answer when i am working with them.
simple thought but
If they are aimed toward's the boiler they are on the return. Pointed away they are on the supply...;) just a guess without seeing0 -
Z vlvs
He's probably showing you how good he is. A 50/50 guess, supply/return, he'll be right half the time. I don't agree w' "if it's pointing to the boiler it's..." The piping pattern can run towards the boiler and still be a supply.
The real check is to follow the piping as best as you can and make the determination. Have someone turn up the tstat and sit at that zone valve. When it pulls around which way is the heated water coming from? This simple test should dictate S or R. Also where are the purge tees?0 -
where is the best place
to locate zone valves? Supply or return. And, when using Honeywell valves, are they less likely to bang if on the return?
Larry0 -
Depends.....
if we were all clayrvoiant like the rest of the people we could avoid these types of problems
... I left my mind reading hat at the habberdaserry
...I havent gotten my X-ray glasses back from the optometrist..... honestly that is nonsence... unless he installed every zone valve in the world with an arrow on it. as to divining what side supply or return it is connected and in which direction its pointed is a laugh...
especially walking up to a new system piped by someone else that has remote valves and the boiler has yet to fire.
.. maybe you could ask him for help at the race track...0 -
Put your hand
on the two pipes to that zone. With that zone calling for heat at the thermostat, the hotter will be the supply. Is the zone valve on this one, or the cooler pipe?
I always zone on the return pipe. If you use the new check pumps you now have positive flow check on supply and return. I've never had a banging ZV problem with the ZVs on the return, either.
hot rod
the cold ones the return...what a simple way to say it:) i am a creature of method the method being put the zones on the return .see,if you found a boiler with zone valve on it and either hot rod or i piped them they would be on the return. then you too could be clairvoyant:) ) my reason is possibly variant from his so i will share the reason...super hot water pounding away at the system components vs cooler water seems the pieces would enjoy a longer life. thats my story and i'm stickin 2 it:)0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
