News from B&G
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,610
NEW CIRCUIT SENTRY' AUTOMATIC FLOW LIMITING VALVE FROM BELL & GOSSETT
Morton Grove, IL, July 1, 2004 - Bell & Gossett has introduced Circuit Sentry', an automatic flow limiting valve designed to adjust hydronic HVAC systems to peak operating performance.
Ideal for achieving optimal operation in variable speed pumping systems, the Circuit Sentry valve balances the system by compensating for hydronic pressure differences. It consists of a ball-type shutoff valve, commissioning measuring ports, and a flow control cartridge that maintains the flow rate at a constant level.
The automatic flow rate cartridge ensures flow rate is maintained at a constant pressure, even under fluctuating pressure conditions, from as little as 2 PSID to 60 PSID, and maintaining the desired flow rate to +/-5%.
The flow control cartridge also facilitates easy flushing of the piping upon commissioning of the system.
Benefits of the Circuit Sentry valve include reduction of time needed for adjustment of the system, an open channel flow control area, and elimination of pipe length requirements before and after the valve.
The Circuit Sentry valve is available in a variety of fixed end connections on valves from 1/2" to 3" in size, with either fixed or sweat fixed ends and a union end with sweat, female or male NPT. Integral and optional P/T-ports for needle system and/or drain are available. The new valve is not for use in potable water systems.
For more information on Circuit Sentry, contact Bell & Gossett at (847) 966-3700 or visit www.bellgossett.com.
Retired and loving it.
