Exterior Rated Boiler
Jacob G.
Member Posts: 9
Who wants to lend a suggestion for a boiler.
This is a Radiant System that requires 60,000 BTU and a max flow rate of 6GPM. The boiler needs to be installed on the exterior of the residence and I'm told I do not have room for a buffer tank. What can give me that kind of flow rate?
I only need 95 degree water and the supply water to the boiler is relatively warm, 55 degrees or so.
- 129 Chimneys & Flues
- 122 Geothermal
