Multi-Press
S Davis
Member Posts: 491
Are any of you guy's using the wirsbo Multi-Press for multi-core tubing, and if so how do you like it?
I am considering buying one to use for 1" and 3/4" supply and return piping as copper prices are out of this world.
Thanks,
S Davis
Apex Radiant Heating
Thanks,
S Davis
Using MultiCor and MultiPress
Really like the products. Use it for baseboard and panel radiator homeruns from a Wirsbo manifold. I already had a Rigid ProPress tool so I bought just the MultiPress jaws. They work just fine on my ProPress tool. Saved me the expense of another "crunch" tool.
Regards,
Rocky0 -
Wirsbo
Yes,like Rocky we already had a Ridgid tool and bought the jaws for Wirsbo multicore.It's way faster than them old, expensive compression fittings.
While your at it,spend a few more dollars and pick up their bending tool.It will make your life easier, and your piping better looking.0 -
We've been using Stadler Fosta-Pex for amlost all our piping for over a year. It's great. Regardless of copper tube prices, the time saved is enormous. On a typical 4 zone pipe up I have noticed time savings of 3-4 hours. That pays for more than a little difference in price assuming that the Pex was more expensive. They also have pressing jaws for their stainless steel sleeve system. We like that system a LOT! Out of thousands of joints over the last year we have not had one single drip!
Just do it!0 -
what is
the list of a Multi-Press ? I really dislike the compression manifolds and the price of them.0 -
Steve,
I've only had 1 leaker on the "pex/Fostapex" fittings, and it was my own damn fault! I soldered a joint a bit closer than it could take. Hindsight being 20/20, lessons were learned, and other than that "misstep", I've had zero faiulres , also.
Still like the Propress anyway.If the tool can make any other system work with it....go for it!
Time IS money, and this is a tool that saves time.(in copius amounts!) Chris0 -
Multi-Press
Thanks for the input, I ordered my Pro-Press today and also the jaws for the Multi-Press system, they should be in next week.
The cost in the seattle area is about $2500.00 for the Pro-Press with 1/2" through 2" jaws.
S Davis
Apex Radiant Heating0
