A Photo of my Vito-Work
I just couldn't help but spray up the parts all fancy. It's begining to be my trademark. Painted boards;-)
Just another example of my work. Be kind.
Gary Wallace
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Gary Wallace
Neat!
It's great how the colors of your system diagram reflect the drawings we could find in a book. The only thing I don't see (and I may be blind) is a set of arrows indicating intended flow patterns.
I hope you keep some of that paint around in case you need to make changes in the future. Otherwise, touched-up changes in the future won't match, and that would be a tragedy, no?
Once again, great install.0 -
Mr. Von Wentzel
Thanks,
The colors reflect the drawings I supply with the system. I allways use a labelmaker with the BIG FAT arrows to indicate all of the flow patterns. (for those who don't know any better)
I don't plan on having to touch it up. Becides the supply (orange) and return (blue) wouldn't change with any additions anyway. This is the first time I chose to use Viessmann Orange instead of my typical red. Too bad Viessmann dosen't have any orange highlights on the Vitodens to pull it all in.
I call it multimedia sculpture.
very nice
piping / design / layout. try not using the header. viessmann has drawings that show primary / secondary piping. we have changed to p/s piping, makes the vitodens easier to install, spend less $ on materials. system responds the same. we are only bidding Viessmann initially. Viessmann is a great product, designed, and manufactured better than any other boiler. i think. once again nice job. marc
That's what I would look for...
... a system diagram is absolutely essential to keep folks 'in the loop' that may come after us. We marvel at the work of the Dead Men, yet how neat would it be to see the system as designed, as built, and a blurb on why? they did what they did. I suppose it may take some thrill from the hunt (such as finding that errant vent in the attic) but it would make for some interesting reading nonetheless.
Sadly, even when such documentation is left behind someone usually disposes of it. The trick is to hide it where no professional cleaning service will look, yet where someone seeking knowledge will find it.
I try to include diagrams with all systems installations I do (Telecom, CAT5, and Coax TV). Typically, I indicate locations via a floorplan of the house, as room designations can change as a function of time... a floorplan should be pretty self-explanatory. However, there is yet another reason to leave a trace behind - customization.
For example, to get ethernet and telco lines into my in-laws office, I had to split the 8-wire pairing in a CAT5 wire along the lines of network and telco. If this is not documented, bad things can result... Similarly, I also use jacket and receptacle color to designate function - Coax (black), Telco (Grey) and Ethernet/CAT5 (blue).
Can you tell I love an orderly system? However, you're taking it to another level by painting the components to match their function. Congrats again.
As for the Vitodens' lack-of-color issue, perhaps you can convince Viessmann to release a special, color-coordinated version just for you? Perhaps a light silvery cover with the big V in in the Viessmann shade of orange? Might be stylish...0 -
Nice work Gary...
and Marc, The Vitodens, in essence, is piped primary/secondary. The Low Loss Header is used when circuit flow design exceed 8gpm. How does one "not use the LLH" if flow rates are beyond 8gpm? What Viessmann drawings are you referring to? Curious minds want to know.
Very clean:)
I daydream this stuff into existence:) My buddy says I gotta Get A Life! ) colour is the thing that needs to be in a persons life and You sir got it right:) it looks Great!0 -
Very neat
Nice work Gary.
Allthought, I could'nt open the second photo ?
Scott
Love it
very original. Mad Dog
ask mr. marshall
we recieved them at viessmann in langley, eric from your co. was there with us. size your system loop for flow needed, boiler basically injects in system loop. works great. marc0 -
Yeah
right on.......I like the colors too, but next time, could you use red and blue in pastel colors? :>)
I especially like the wiring from the Taco SR pump controller to the circulators; very nice.
Alan
Colors
Very nice! You gotta love it.
Gary from Granville0 -
What's that
Gary, what type of heat emitters is that nice looking piping hooked up to and what is your max temp set at on the Vito?0 -
Spirovent in right spot?
Just curious as to why the air seperator is on the system side of the system?0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
