temp valve
curiousity kills
Member Posts: 118
Question about a temp valve.This is for a domestic hot water situation, If you adjust the mix to 125 will it remain at that temp regardless if the hot side increases Is there a point when the mix will increase because the hot increases. Im using a taco type valve.
regardless of the valve.....
if it says it is a porportional mixing valve....Thats what it means. It doesnt matter who makes it.0 -
Watts 70A
I've found that the Watts 70A tempering valve does not keep the outgoing temperature very steady with highly variable inlet temps. Also all of them I've installed have failed within the first year, also they don't meet the most recent certifications. I've converted to using one of the better ones, like the Taco or Honeywell. They may have greater resistance to flow, but I'll design around it.0 -
temp valve
My question stems from a recent install of a gas water heater with a mixing valve[ it is now code here in new hampshire] Out of the box the taco mixing valve is set for 130, if I turn the temp on the gas vale to aprox 145 and walk away will the temp valve keep at 130 or should I stay for an hour to check??????0
