Don't Know How to Solder
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
and the "irrigation specialist" had to tie in to the copper domestic water system.
I've got to hand it to the guy; he used epoxy to join the fittings which provided a threading point for his PVC. It lasted more than 10 years until we came along and re-piped the bathroom.
But now, someone has come along with a product you can buy:
http://www.justforcopper.com/cb1b.htm
Watch out, ProPress
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Watch out, ProPress
I read an article about using epoxy instead of lead solder in Popular Mechanics about 15 years ago when they were first baning lead solder in potable systems.
Matt0 -
solder
I went to career day with my friend a plumber where we had great fun teaching 4th graders to solder 1/2 elbows on to little pieces of copper pipe. Looks like this guy could use a lesson. J.Lockard0 -
Read an
article in yesterdays paper about the Hardware show in Vegas where someone has come out with a product to "glue" copper together.
It is some type of liquid compound that wipes on the pipe, in the fitting, you give it a couple of twists and it hardens up.
Has anyone else heard of it or seen it in use?0 -
Yes, Jack
I did see that product at the Homebuilders Show in Vegas this year. It was at a Home Depot booth and display.
Sorry I didn't have a camera that day.
hot rod
\"copper weld\" is a one way trip, just like propress
Copper pipe glue.
Alan.
I had a look at the product you gave the link to.
Has anyone used this product?
It looks a great product. Could it be the end of soldering?
Thanks Alan.
Regards
Jimmy Gillies0 -
My dad fixed a leaking lead and oakum joint in a horizontal soil branch in his house with Quick Crete--at least 30 years ago and it still doesn't leak or clog. It ain't pretty but I've gotta' hand it to him for ingenuity and long lasting "quick fix".0 -
glue make a mess
Had a contractor use so much of this stuff he plugged up a pressuring balancing shower valve. A little torch work got the stuff out, said it was the second time he's had this problem.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
