Inert gas testing
Steve Miller
Member Posts: 115
Is anyone doing inert gas testing to find cracked heat exchangers on furnaces? If so, what do you think?
Thanks in advance, Steve M.
Inert gas testing
Thanks in advance, Steve M.0 -
By inert gas I assume
you are using nitrogen? I have used low level Methane (.5cc concentration) with a methane detector with very good results. Just about any gas in small concentration can be used as long as you have a detector sensitive enough to pick up the trace level of the gas. Most of the Methane detector systems for heat exchanger testing come with a calibration gas for setting up the detector correctly.0
- 119 Geothermal
- 394 Solar
