system 2000
Rudy
Rudy Member Posts: 482
Has anyone had strange noises from the system 2000 boilers. The unit is set correct temp and psi. Maybe steel moving noiseor combustion noise. some sort of banging in the winter. high limit works fine.thanks
  • lchmb
    lchmb Member Posts: 2,997
    generally
    I haven't run across one banging without a reason. Have you been able to find what area it is happening in? Or any other information IE when it started, what changed?
  • Robert O'Connor_3
    Robert O'Connor_3 Member Posts: 272
    Sound like
    a boiling type noise? Percolating?? Could be dirt in the boiler. Call Energy Kenetics, they will help you out with this. ~Randy
