well tank
lakota
Member Posts: 32
What is the proper way to test the air pressure inside a Well X-Trol tank that is in use. Thanks for any help.
Isolate, drain, test...0 -
Use
a tire gage to read the pressure - after the "static" pressure of the system has been put to zero.
If you try the Schraeder valve reading with a tire gage with the system connected, you will read system pressure - not the bladder inside the expansion tank fill pressure.
Think about it.
well tanks
As ken said,
With system pressure at ZERO, test the air side of the tank (shouild be a schrewader air valve on top of tank).
tank pressure should be the TURN ON PRESSURE LESS 2 pounds. Example, Pressure switch set 30/50 air pressure should be 28.
Gawd..I forgot more than i now know:))
Thanks for the input. Wasn't sure if you had to drain the tank or not.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
