Help with Vitodens piping
This drawing is based upon Viessmanns suggested layout for the Vitodens. Ive made only minor adjustments. Im looking for any defects in this rather simple design. The drawing is unfinished and I would like your input as to how I may improve and simplify the near boiler piping.
Im unsure if the Spirovent should be placed where I currently have it located. The Vitodens has its own air eliminator.
Please share your thoughts
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
why 4 high temp pumps? you can only set the curve for 1 high temp pump so usually I size for 1 pump, sized for the entire zone. Additional pumps(ie: HX;HW Air Coil,etc) can be used, and controlled by a separate relay(s), but proper design may eliminate the additional pumps. Also, no need for a Spirovent after the LLH, as long as yuou have puirge valves.
vitodens piping
gary,
your posted picture is not working. maybe it's me.
e-mail me and let me look it over.
stevew@avcosupply.com
thanks,
steve0
