RE:Replacement for Kewanee
Blackoakbob
Member Posts: 252
Re: Replacement for Kewanee
I'm looking for suggestions for a replacement boiler for Kewanee square heat type boiler about 1969 vintage, dual fuel burner nat gas and #2 fuel oil, limited entry space to access the boiler room, oh, and low pressure (10 Psi) steam
Input < 900,000 mbh
Best Regards,
Blackoakbob
Thanks for your replies. No further reply is needed.0 -
Hum..
....I like the new VaporPower/Iron Firemans from what i've seen.I had good luck with the VaporPower watertube boilers in the service (picture a G.E.downfired on steroids).And thay offer duel-fuel.I have also had good luck with the Patterson-Kelly "washmachine" boilers but I think there only
offered in gas/hot water.Fulton makes "skid" boilers but I'm not sure about in duel-fuel.Why do I forsee the porkchop comming out and a scotch-marine going in....0 -
Bob,
There are probably 20+ manufacturers of boilers in that range.
There is also 10+ manufacturers of dual fuel burners.
The boiler makers that come to mind would be:
Weil McLain, Smith, Burnham, Peerless, Utica, Buderus, Slant Fin, Hydro-Therm, Crown, Easco, C/B, Columbia, or anyone esle that might pop up in a Google Search of "steam boiler makers."
Burner wise, I can think of a few:
Power Flame, IC, Iron Fireman, Gordon Piatt, Webster, etc.
Hope this helps.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
