steam rad edr question
clammy
clammy Member Posts: 3,183
Recently looked at a steam job it had some rads that i,ve rarely run into the boiler was a oil to gas conversion they installed a gas burner gun on the old oil boiler .The rads in question where cast iron 6 x 6 with 3 rows wide 3 high each row was 2 x 2 with fins could really use a edr to go with thanks peace
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,610
    I'm having
    a tough time visualizing that, Clammy. Can you post a drawing or a photo?
    Retired and loving it.
  • clammy
    finned ci rad
    Dan it,s actually some what like a conventor these units are recessed in the walls with steel covers.They look push nipple assembled ,each side having a header one side supply from bottom and the other side has one a straight air vent connection .Each header has 9 connection on them 3 front to back and 3 bottom to top the elements running acrossare cast iron with small vanes cast into them ,they measure a little under 2 x 2 .There are a few regular steam rads there some 3 ,4 and 5 tube of varying lenghts .These rads i am looking for the edr on are in areas of the home which have not had any work done on ,they kinda remind me of convection rads in gravity air systems or ones you would see under a small raditor grate .Sorry i tryed to draw a picture on the computer but a 1 st grader would have done better i'll try to get a photo of them don,t quite have a scanner yet thanks and peace
    NJ Master HVAC Lic.
    Mahwah, NJ
  • DanHolohan
    Okay,
    I'll wait for the photo. Thanks, Clammy.
  • Ken_8
    Ken_8 Member Posts: 1,640
  • clammy
    that,s a them
    The photo of the arco rad is the devil do you have any edr infromation on them by the foot .they are handsome aren,t they thanks for any info peace
    NJ Master HVAC Lic.
    Mahwah, NJ
  • clammy
    edr
    hey ken any chance you have the edr for those bad boys now would ya thanks and peace
    NJ Master HVAC Lic.
    Mahwah, NJ
  • DanHolohan
    Here you go:
    ARCO
  • clammy
    thanks
    thank you both ken for posting the pics and dan for suppling the edr you guys are the best now i can get on withsizing the boiler and pricing the job out ifi,m lucky and the ho wise i'll be posting pics of her soon thanks again and peace clammy
    NJ Master HVAC Lic.
    Mahwah, NJ
