Gravity radiator connections
Ted_9
Ted_9 Member Posts: 1,718
I remember reading in on of Dans books that if you have a gravity hot water system and the supply and return are on the bottom of the rad, using a circulator with a new boiler will make the hot water shoot from one sid eto the other without properly heating the rad. Am I remebering this correctly?
Should I repipe the rads to go supply high and return low?
Should I check for an oriface in the rads?
