Munchkin Vision1, Boilermate?
Nick_11
Member Posts: 25
How Can the Boilermate WH-7L-DW be wired to operate with the outdoor reset and indirect Water Heater features of the Vision1 package?
Any indirect water heater can be piped into the Munchkin with Vision control if you follow the piping diagram. The temperature sensor normally is inserted into a well, but the WH7 may not have a well. I would attach the sensor on the bottom of the tank to get a good spot to sense the tank temperature. The WH7 only has a 3/4" coil, though. Make sure that you are getting enough flow through the Munchkin when the system is on DHW priority.
Jim Eastman0 -
Use the wires (Purple, I believe) that Amtrol provides , and attach them to the two blue wires for the aquastat in Vision 1. This will allow the Boiler-Mate the benefit of Vision 1 priority. You would set the temperature by way of the Amtrol Smart control, and not the Munchkin display. It will simply act as an on/off control.
Guy Woollard
Heat Transfer Products0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
