Is Viessmann the only company
S Ebels
S Ebels Member Posts: 2,322
Is big V the only company that makes their wall hung condenser in house? I'm talking about heat exchanger and burner, not fans and gas valves.
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    Buderus Wall Hung Boiler
    This September, Buderus is releasing a wall hung, here's the specs... Rick
  • S Ebels
    Just curious
    It seems as though every other manufacturer is just assembling parts instead of doing an in house design.
  • Ken_8
    Ken_8 Member Posts: 1,640
    How about the
    S/F "Prodigy"?
    Or the "Heat Wise"
    Perhaps the Monitor MZ?
  • DaveC
    DaveC Member Posts: 201
    Prodigy boiler is...
    not a condensing design. Does Heat-Wise (Bola Kamath's company, here in Long Island) make boilers, or just burners?
  • Steve Stackhouse
    Steve Stackhouse Member Posts: 1
    wall-hung gas boilers w/domestic
    Viessmann makes an excellent product, but only the 25-91k btu unit has domestic.
    Baxi has a boiler that is full-mod, wall hung with or without domestic up to 105k btu. 98 pounds, fully contained, non-condensing direct vent boiler. The company has been in business for over 40 years, and we have several hundred of these units in the field.
  • DHW on Vitodens
    Steve,
    The small plate heat exchanger in the little Vitodens is a nice option but a better choice is to buy the regular Vitodens with the DHW enable kit. Seperate ports on the bottom of the boiler to run to your indirect water heater and the computer/boiler have built inpriority and temp over ride. PLug and play as you will.
    This enables you to size the DHW to the house. PIck any indirect whether a Viessmann 316TI V300, a Viessmann enameled steel V100 or any other manufacture of indirect. I've couples the Vitodens with the V300m V100, Weil McLain Plus, Crown Megastore, Super Store and Storex tanks.
    Steve
  • steve gibbs_2
    steve gibbs_2 Member Posts: 5
    Plug 'n' Play
    Remember, with Viessmann its Plug 'n' Verk. We play later.
